Meet OceanBase AI Lakebase, the unified database for operational data, real-time analytics, and AI.
Explore ->
Meet OceanBase AI Lakebase, the unified database for operational data, real-time analytics, and AI. Explore ->
AI Agents Need More Than Storage. OceanBase Built It Into the Engine
Yingying Yao
Yingying Yao
Published on April 17, 2026Updated on 2026-11-22
7 minute read
Key Takeaways
  • AI agents interact with databases hundreds of times per decision cycle — hybrid search, memory retrieval, and context updates need to happen in milliseconds, not across a fragile chain of external API calls.
  • The two mainstream approaches — bolted-on vector plugins and standalone vector databases — both break in production: one can't co-optimize across search types; the other demands a multi-hop glue architecture that collapses under load.
  • OceanBase 4.4.2 LTS embeds vector search, full-text search, and AI inference (AI_EMBED, AI_COMPLETE, AI_RERANK) inside the SQL engine, collapsing the agent's six-hop data pipeline into a single query backed by battle-tested ACID transactions.
  • For thirty years, databases were designed for humans. DBAs wrote SQL. Applications talked through ORMs. The access patterns were predictable: batch reports, CRUD operations, the occasional analytical query.
    That assumption is breaking. AI agents — autonomous programs that perceive, reason, act, and reflect — are becoming the primary consumers of production databases. An agent completing a single task might query the database dozens of times: retrieving conversation history, checking business rules, searching a knowledge base by semantic similarity, updating its working memory, and logging its reasoning trace.
    Each of those interactions is context-dependent and latency-sensitive. A 50ms penalty per query compounds to a full second over 20 iterations. In an agent workflow, that's the difference between "intelligent assistant" and "frustratingly slow tool." And unlike traditional application queries, agent access patterns are hard to predict and nearly impossible to cache.
    The database is no longer just storage. It's the agent's memory, knowledge base, and reasoning substrate — all at once.
    What OceanBase 4.4.2 LTS Delivers for Agent Workloads
    At a high level, OceanBase 4.4.2 LTS provides:
  • Native vector search — HNSW and IVF indexes built into the storage engine, not bolted on as a plugin. Dense and sparse vectors, with L2, cosine, and inner product distance functions.
  • Hybrid search in a single SQL statement — vector similarity, full-text BM25, and relational filtering execute together, with the query optimizer co-planning across all three index types.
  • SQL-native AI functions — AI_EMBED, AI_COMPLETE, and AI_RERANK as first-class SQL functions, so agents can run a complete RAG pipeline in one query without leaving the database.
  • Production-grade reliability — the same ACID transactions, Paxos-based high availability, multi-tenant isolation, and elastic scalability that run banking core systems.
  • Four Requirements Agents Place on Databases
    Agents don't just query tables. They operate across three categories of data simultaneously:
    Data Type
    What It Contains
    How Agents Use It
    Factual dataStructured business records — orders, inventory, user profilesGround truth for decisions
    Procedural dataSOPs, task graphs, workflow definitionsStep-by-step execution plans
    Contextual memoryConversation history, user intent, intermediate reasoningContinuity across interactions
    A single agent action might require a vector similarity search over a knowledge base, a keyword match on domain-specific terminology, and a relational filter on time range and access permissions — all in one query. Any architecture that forces these into separate systems forces the agent into a multi-hop pipeline with compounding latency and failure modes.
    High-frequency micro-writes, millisecond reads
    Agent data access looks nothing like traditional CRUD. Agents write small, frequent "memory fragments" — a conversation summary, an inference result, a tool response. The data units are small, but the access intensity is high.
    This pattern demands a storage engine optimized for high-concurrency small transactions with immediate read-after-write consistency. OceanBase's LSM-Tree engine and distributed transaction architecture are designed for exactly this workload: high-frequency micro-writes that are instantly readable.
    When agents move from demos to production — financial risk assessment, medical triage, government approvals — the stakes change. Every data inconsistency or system failure carries real consequences.
    The data layer behind production agents needs ACID transactions for atomicity, multi-replica high availability for fault tolerance, multi-tenant isolation to prevent data leakage, and fine-grained access control to constrain what each agent can see and do. There's a subtlety here: agents are autonomous. They keep running while you sleep. A bug in an agent can cause batch-scale, sustained damage — making reliability requirements higher than for traditional applications, not lower.
    Database as a callable tool
    In agent architectures, the database isn't a hidden backend. It's a first-class tool that the agent invokes directly. The agent decides when to query, what to query, and how to query — ideally completing the entire data retrieval and reasoning pipeline in a single call.
    The ideal call chain is Agent → Database → Result. Not Agent → Embedding API → Vector DB → Business DB → Rerank API → LLM API → Result. Every hop adds network latency, a failure point, and operational complexity.
    Why Current Approaches Fall Short
    Approach 1: Relational database + vector plugin
    Bolting a vector extension onto PostgreSQL or MySQL is the path of least resistance. The ecosystem compatibility is real. But the limitation is structural: the query optimizer has no cost model for vector indexes. It can't co-plan a query that combines semantic similarity, full-text matching, and relational filtering.
    In practice, this means "retrieve by vector first, then filter row by row" — a serial execution pattern that degrades rapidly as data scales. You're running a 2026 AI workload on a query planner designed for a different era.
    Approach 2: Standalone vector database
    Dedicated vector databases deliver strong ANN performance. But agents don't only need semantic search. They also need business data lookups, transactional writes, and complex analytical queries — none of which a vector database handles.
    The result is two systems in production: a relational database and a vector database, glued together by application-layer sync and result stitching. A single agent query can trigger five or six network hops and multiple format conversions. Any hop that times out breaks the entire chain.
    This "glue architecture" solves the capability problem but creates a reliability problem. For teams putting agents into production, it's not a technology choice — it's technical debt.
    OceanBase's Approach: Build It Into the Engine
    Rather than patching capabilities onto the architecture, OceanBase integrates vector search, full-text search, and AI inference directly into the database kernel.
    Native vector indexing
    Vector is a first-class data type in OceanBase, not an extension. The engine supports both dense and sparse vectors with multiple distance functions: L2 (Euclidean), cosine similarity, and inner product.
    Two index families cover different trade-offs. HNSW graph indexes deliver sub-millisecond retrieval for latency-critical online workloads. IVF indexes use clustering to reduce memory footprint for larger datasets while maintaining high recall. Quantization options — scalar (SQ), product (PQ), and binary — let you tune the precision-cost trade-off per workload.
    These vector indexes are deeply integrated with the LSM-Tree storage engine, ensuring that vector indexes remain consistent and queryable even under heavy concurrent writes.
    With vector, full-text, and relational indexes co-existing in the same engine, OceanBase's query optimizer can plan across all three. A single SQL statement can combine vector similarity recall, BM25 keyword matching, and structured column filtering, with results merged through Reciprocal Rank Fusion (RRF).
    This isn't just a convenience. It's an architectural advantage: the optimizer has a unified cost model across all index types, so it can choose the optimal execution path rather than falling back to serial retrieve-then-filter. All search operations share one transaction context — no cross-system consistency issues, no sync pipelines.
    AI functions inside SQL
    OceanBase wraps Embedding generation, LLM inference, and result reranking as SQL functions: AI_EMBED, AI_COMPLETE, and AI_RERANK. An agent can execute a full RAG pipeline — from question to answer — in a single SQL statement:
    -- A complete RAG call: one query, one round trip
    SELECT AI_COMPLETE('qwen-max',
            CONCAT('Answer based on the following context: ',
                           (SELECT GROUP_CONCAT(content)
                            FROM knowledge_base
                            ORDER BY VECTOR_COSINE_DISTANCE(
                                embedding,
                                AI_EMBED('text-embedding-v3', 'user question'))
                               LIMIT 5),
                              '\nQuestion: user question'))
     AS answer;
    For agent frameworks, this makes OceanBase a "super tool." The call chain collapses from six hops to one. Fewer hops mean lower latency, fewer failure points, and simpler error handling.
    Battle-tested reliability
    OceanBase has been forged in financial core systems — Ant Group's payment processing, banking ledgers, insurance platforms. The same ACID transactions, Paxos-based multi-replica consensus, multi-tenant resource isolation, and online elastic scaling that serve those workloads now back agent data operations.
    When agents graduate from prototypes to production — handling financial decisions, medical queries, or regulatory workflows — the data layer must be infrastructure that has already survived at scale. That's not a feature you bolt on; it's a property of the system's history.
    What's Next
    OceanBase is exploring several capabilities purpose-built for agent workloads:
  • AI Columns — declarative derived columns where the database handles model invocation, result caching, and incremental updates automatically. AI Columns participate in standard SQL operations (SELECT, WHERE, JOIN) like any other column.
  • Row-level access control — fine-grained permission boundaries so multiple agents operating on the same table see only the rows they're authorized to access.
  • Massive logical table support — when agent platforms scale from hundreds of enterprise tenants to millions of individual users, logical table abstraction provides per-agent data isolation on shared physical storage.
    Deploy OceanBase 4.4.2 LTS — quickstart guide
    X
    linkedin
    mail
